You're in a pretty extreme situation. Check the path profiles for the Vegas stations (click on a listing in the table of your report), and you'll see that you're almost completely shadowed by mountains. Only KVBC, transmitting on Ch. 2, scatters sufficiently over the mountain to be picked up directly. The antenna you've picked out will be about the best you can do for the situation. I'll let others comment on the amplifiers/splitters.
You will have much better luck with the translators that are listed first in your report.
