					Originally Posted by slowhike  I'm hoping to get a few more suggestions.I'm getting weaker signals than before, at least on some stations.
 My TV does not have a signal meter, so I have to do some guesstimation in the following report.
 I'm quite sure I was seeing some increase in pixialtation & drop-outs as the large oak trees (two at each end of the house) began to leaf out.
 And I believe I saw a further increase in pixialtations drop-outs after adding the 4-way splitter I described in my last post here.
 The signals are certainly not as reliable as they were a couple months ago.
 As I read other threads about pre-amps & such, I see that a pre-amp does not improve the signal, it just pushes it further down the line.
 So I'm wondering if I would benefit from a stronger antenna.
 Sure do wish I had a signal meter.
 Man get yourself this antenna and a rotor and if needed get a signal amp for the mast,
you can use the one you alredy  have above or under  with a uhf/vhf separator.
http://www.newegg.com/Product/Produc...-pla-_-NA-_-NA
