Old 10-Apr-2012, 7:05 PM   #2
Electron
Tv antennas and Tv reception
First disconnect the radio shack amplifier and put it in the trash. Then aim the ANT751 antenna at about 10 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Then disconnect the coax from the splitter that goes to the family room. Then connect a Known To Be Good coax to the splitter and run the coax direct to the family room tv. In the future -> If <- a amplifier is required use a Channel Master CM3412 distribution amplifier.
