It will be one of the most capabale of holding up. That's one reason why we recommend it.
If you study your TVFool report (and I recommend that, including the Singal Analysis FAQ that's linked to), you'll note that the stations Electron is pointing you to are the main Denver ones. There are stronger stations, including some very close to you. However, those are mostly home shopping and religious programming outlets which you are not interested in. Only KPXH will help, as it relays ION programming from Denver. While pointing south, you may get a FOX and a CBS station from Cheyenne off the back of the antenna.
To reinforce what Electron told you, the predicted signal levels from Denver dictate a roof-mounted antenna. Good luck!
