Old 10-Apr-2012, 9:59 AM   #2
Electron
Tv antennas and Tv reception
A simple reception situation. Many as in - Many - digital Tv stations/channels will be received. Install a Winegard HD7696P antenna with a Antennas Direct CPA-19 preamplifier , above the highest roof , aimed at about 177 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com. Buy the ronard mounts from solidsignal by typing the word ronard in the solidsignal search box or buy from ronard. Here are places to buy antennas and etc. , http://www.winegarddirect.com , http://www.solidsignal.com , http://www.amazon.com , http://www.antennasdirect.com. Use standard RG-6 coax (No need for RG-6 quad shield) from the antenna to the connection point that goes to the other coaxes that go to the Tv up stairs and the Tv in the basement. For one Tv connected , no splitter is used , For 2 Tv's connected use a simple common 2 way splitter that sells for $8.00 or so. A supper wiz bang gold plated HD compatible splitter that sells for $49.95 is not required.
