Old 10-Apr-2012, 4:30 AM   #14
Products such as Coax-Seal and Scotch #2228 are able form a water tight seal when wrapped over connectors. I have seen water wick between layers of standard electrical tape so I never recommend using vinyl electrical tape alone for weather proofing, but I always wrap a layer of vinyl electrical tape over the sealing tape as a protective cover to block UV rays and to keep dirt from accumulating on the tacky surface of the sealing tape.
