The make and model of your antennas is going to be helpful information. Do the antennas have integral baluns? Or are there balun/matching transformers connected to terminal posts?
What weather sealing measures have been taken to keep water out of the coax and connectors? If the antennas were installed at about the same time and have been subjected to the same weather, I wonder if water has gotten into the coax.
In your first post you said, "My husband has switched cables, TVs and tried everything he can think of." Does this mean that the cable from the antenna was replaced with a new, factory assembled cable?
(I'm concurring with the gist of Electron's thought in post #7 of this thread.)
