Tv antennas and Tv reception
If you have not watched or listened to Digital Broadcast Television you are in for a very pleasant suprize the picture and sound are better then cable or satellite. . The Tv/s Must Scan for the Digital Broadcast Tv Channels sometimes called the 'Air Channels' or 'Antenna Channels' in the Tv set up menu because the television transmissions travel through the air from the transmitting antenna to the receiving antenna. Do Not scan for cable tv channels.
