Old 9-Apr-2012, 8:02 PM   #1
dakota dan
Question Can you use electrical outlets as TV antenna?
I have a rural home that will not work for easy OTA external antenna setup. Broadcast stations are 60 miles away and the terrain is hilly.
I would like to know if anyone has knowledge of a solution to make an entire building an antenna by using an electrical outlet as the antenna feed. I use outlets today for easy room to room Internet connections and works great.
dakota dan is offline   Reply With Quote
