Old 31-Jul-2010, 2:13 AM   #5
wideBody1
Thanks all. I read all the links and learned a lot. So.....
Wow, I moved my antenna into the horizontal position, NE/SW as indicated. Went from 1 channel to getting the first 7 or 8 channels in my list. However, it certainly doesn't get all the channels in the green like I was hoping for. How much do you think it would help if I moved the antenna outside and up higher? Not sure if i can do it permanently, just curious.
I think i'm gonna go for the 3.99 rabbit ears / loop combo. Except, I can't find that for 3.99. I did find this: http://www.radioshack.com/product/in...ductId=2103077 -- is that what I should get?
And lastly, if none of that works, this is the product that is being recommended?
* http://www.amazon.com/Terk-Technolog.../dp/B0001FV36E
wideBody1 is offline   Reply With Quote
