wideBody1, you could probably get by with a $3.99 rabbit ears/loop combo from Radio Shack, but I would try putting your existing rod antenna horizontal, with the ends pointing NE/SW. If neither works, then a Terk HDTVi would be the last step. Under no circumstances should you have an amplifier connected. The stations at the top of the list that have their power levels highlighted in red can easily overload your system.
Reason: Edited for more courteous tone
