Old 9-Apr-2012, 3:29 PM   #2
Dave Loudin
For the Waco stations to the northeast, that will be fine. If you were interested in Austin to the south (which is doable), I would go a bit larger in the HBU line with either a separate antenna and feed into an A/B switch or a single antenna with a rotor (not terribly likely in an attic.)
