I don't think so. If you follow the advice given so far, I think you will be fine of TV reception. Putting an antenna on the roof gets you out of a lot of "clutter" (walls, cars, stuff inside the walls, neighboring houses, etc.) that makes reception difficult indoors. With a "clean" signal from your roof using the right size antenna, you should be fine.
BTW, the FM band is just above channel 6, so if you get a TV antenna that supports channels 2-6, you can probably hook up the same antenna feed to your FM receiver to get great reception. Antennas designed for high-VHF only (i.e., channels 7-13 or 7-69) don't go down far enough to help with FM reception.
