Old 9-Apr-2012, 9:22 AM   #7
Most TV's with built-in DTV tuners force you to scan for new channels. A few TV's and converters will let you manually add channels... If you are able to manually add the channel and the tuner has some sort of signal metering, you would be able to tell if you're seeing some signal even if you can't get a lock.
If you know you're seeing some signal, then it may be worth trying an Antennacraft Y10713 or even a stacked pair. http://forum.tvfool.com/showthread.php?t=1024
