Old 9-Apr-2012, 6:41 AM   #7
Reception of KAZT at your location is more difficult than other stations because they are transmitting less power than most other station.
To receive a reliable signal will require using a high gain UHF antenna such as the Antennas Direct 91XG or Winegard HD9095. A high-input preamp such as the Antennas Direct CPA-19 will also be needed.
It's also possible you will need to use a tower to get the antenna up out of the shadow of the hills/mountains that are about 10 miles NW of you.
What is the make and model of your existing antenna?
How many sets are going to be connected?
