Tv antennas and Tv reception
It is possible to worry ones self into not doing any thing. Install the CS2v antenna as directed. Use standard RG-6 cable. RG-6 quad coax is not required. Two antenna mounts that are good for you are the chimney mount or the eave mount. Mount the antenna so the antenna is about 4 to 6 feet above the high point of the roof. Outdoor tv antennas receive the best with elbow room. Out door antennas receive the best with a clear view of the transmitting antennas. The CS2v will supply signal to one tv or two tv's with a 2 way splitter. A preamp will not be required for one or two tv's.
