Yagi now set atop chimney west end and cable also enters west end (foundation).
If I set up the second antenna on the east end, I would drill a new opening for cable at the east end and that's closer to my current DA and balance splitter.
Plan now is to re-cable the Yagi with new RG-6 and connectors, using the specified pre amp.
If that does not improve WLIW, will add FM trap between ant and pre. If that does not work will try the band pass filter for 21. If that works, will add appropriate A/B switching and get all channel as addn array so I can grab that low VHF you pointed out together with everything else (but for 21 WLIW which would stay via the Yagi). Many thanks and I will def report back!!!!! Happy Easter.
David
