Thanks Gents...great thinking and appreciate your expertise!
I'm wondering if the existing Yagi array (with new additions of CPA-19 and band pass filter) ought to be mounted to one end of home and an all channel array (Winegard as recommended) should be mounted at the other end of the home.
Having the Yagi at one end of the home (East) will make a significantly shorter cable run. Or can the two separate arrays (separately cabled all the way to the A/B) simply be stacked on the same mast?
I confess knowing nothing about the high VHF antenna suggested by GroundUrMast, and plan to look into carefully this AM before deciding upon a plan.
Again, many thanks.
David
PS...I assume that using the band pass filter for WLIW 21 obviates the need for amy FM trap?
