Old 29-Jul-2010, 4:46 PM   #27
Billiam
Originally Posted by chumster View Post
Thanks again for the information. I want to make sure I understand the grounding procedure. I am going to order a 4ft copper grounding rod, a grounding block, and #10 copper wire. is that all I need? I want to make sure before I place my order. Thanks again!
Best to consult a local electrician that is up on your local building codes.
I do know this. You should use 6 or maybe 8 gauge wire and best to use a 8 foot copper rod for the ground.
