Old 8-Apr-2012, 7:11 AM   #15
If only turning a panel antenna, the trust bearing would not be needed.
If you're swinging a larger antenna such as a 7-69 type, a thrust bearing is going to take a great deal of the load off of the rotator housing.
If the CM9521a is back ordered, consider the NTE U-106 and TB-105
