Old 8-Apr-2012, 4:44 AM   #2
Dave Loudin
Looking at your report, there is a PBS station and several weirdly named channels very close by. Those are repeaters that bring nearby stations into otherwise shadowed areas. In particular, W42DG relays WJAC, the NBC station. W36BE brings in WNEP, an ABC station. WHVL-LD provides MyNetwork and America One programming. That leaves CBS and FOX, which are carried by stations a bit farther away and in a different direction (WATM relays WWCP also). This makes picking a single fixed antenna choice.
The one saving grace is all your stations are UHF. It's possible that an Antennas Direct DB-4e would work as a "set and forget" solution. I'd like to hear from others before you commit to that.
