Old 7-Apr-2012, 3:30 PM   #2
Dave Loudin
Wow, I am jealous! The 7694 will be perfectly fine, and will capture enough signal to drive all 6 outputs without an amp. So, don't get an amp! Do get cable terminators to prevent loss out of the unused ports.
With the predicted signal strengths at your location, you could stick a short piece of bare wire in each TV's coax jack and get over 10 stations with a few dropouts. With your proposed setup, you should get everything down to KVQT-LP (if it's switched to digital). You could take your station list over to your neighbor and check how many he gets. What he gets will be perfect, since that's the nature of DTV. He just might not know what he's missing.
