Old 28-Jul-2010, 8:51 PM   #26
chumster
Thanks again for the information. I want to make sure I understand the grounding procedure. I am going to order a 4ft copper grounding rod, a grounding block, and #10 copper wire. is that all I need? I want to make sure before I place my order. Thanks again!
Originally Posted by Billiam View Post
Standard rotor cable should be fine. 3 conductor wire I think is what works for most rotors. The Centronics uses 3 conductor wire.
chumster is offline   Reply With Quote
