Old 7-Apr-2012, 3:36 AM   #15
douflag
Originally Posted by Electron View Post
Your unit is the one with the red star. If rectangle box in lower right corner of your unit is a balcony , put the antenna out there close to the edge , and aim the antenna to the east south east and south. Here is how to aim indoor type antennas , http://www.kyes.com/antenna/pointing/pointing.html
By pointing the antenna E/SE/S, would I need to have buildings in the area to pick up the reflected signals? If so, that's a problem, because there isn't much for a signal to bounce off of by where I'm at.
Yes it is Ok to use a long coax to connect the antenna to the Tv. No complaining about a coax cable running through your apartment , will you pay for tv reception or watch for free??
Nah, I have an alien looking antenna (HDTVi) now, so that extra cable isn't going to make a difference to me. I think you may have mentioned about flat coax cables in other posts. Can you recommend one? Thanks!
Could move to the unit on the north end of the building.
Well, that would just be impractical. lol
douflag is offline   Reply With Quote
