Boston is considered an all-UHF city. Unless you want to experiment with adjacent markets, there really isn't much else to be done if those channels are received reliably. For example, WMUR, ABC in Manchester, is available if using a high-VHF channel. WMUR's network programming will usually mirror that of Boston's WCVB. There are two VHF stations out of Providence that are likely receivable, the CBS and Fox affiliates. Again, the network programming will be generally the same as the Boston affiliates.
You'll have to look at your TVFool plot to see if there are nay of those or other stations that are on you list of stations you'd also like to have. If so, we can look at what might be needed.
