I'm not convinced you need an amplifier at all. To answer the question with some confidence, how many tuners are you going to connect?
Depending on your answer to that question, it's entirely possible that the previously suggested 7-69 antenna could drive the system with no amplification.
If you have a large number of tuners to connect, the CPA-19 is the best choice I can think of. Alternately, the HDP-269 and CM-341X series would be capable as well.
