^^^In the early 90's I had two very large antennas come down off a tower I had in my backyard thanks to bad weather. Thus, whenever I install a new antenna I make sure it won't take out any important objects like a window or electrical wires. Cables TV wires? I situate the antenna in a spot where if it does fall, it will fall directly on the now uselss and disconnected cable coax. :-)
If you have a stink pipe aka vent pipe on the roof, you may want to use that instead of the stucco structure you mentioned. Unless you know what is underneath the stucco, it would be wise not to attach a chimney strap. May only be 2 x 4's and particle board covered by the stucco. A vent pipe that is sturdy and not shaking around should be adequate as long as you don't use a lot of mast or a huge antenna like the Winegard 8200u. I have a Antennacraft MXU59 and Winegard YA-1713 on my stink pipe and I've had no issues with them moving around.
