Because you're using Tivo, I'd recommend using an outdoor mounted antenna. You'll enjoy better signal quality which will translate to more reliable recording.
A mid size all-channel antenna such as the Winegard HD7015 should be able to drive a 4 or 8-way passive splitter. Aimed at about 30° you'll have a lot of programming to choose from.
Connecting multiple sets is accomplished by using a splitter. An example is the Ideal brand #85-134: http://www.homedepot.com/webapp/wcs/...&storeId=10051
