Do not try combining the two antennas. It rarely works. Either use one antenna with a rotor or use an A-B switch to select the active antenna.
This past Saturday, I picked up (briefly) stations from Dallas, TX and Austin, TX, which are about 250 and 350 miles away, respectively. No luck repeating this feat so far :>(
Tropospheric ducting. Don't get used to the out-of-market stations because the signals vary tremendously over relatively short periods of time.
