As promised here is my report, I am getting all of the metro stations plus St. Cloud(ION) in all weather conditions. In clear conditions I can also receive (3abn) and mankato on some tuners.The weakest tuner is in the newest tv, however it generally is not a problem because that is where the tivo is hooked up.
Antenna is in the attic at a height of approx 28'agl pointed between 48-52 degrees.
I was able to get some signal with the Lava antenna as well, I'm going to try to use that for an RV antenna.
Thanks for the help
Paul Hastings
