					Originally Posted by  kimNJ
				Thanks Electron! I do have the antenna in the window and my son found a compass and we did point it at 347 like you suggested and are able to pick up one more station (Spanish). So now we're up to two. Looking forward to any other suggestions that won't be too costly that will hopefully enable us to pick up a few more channels.
 Your TV Fool report indicates you need a large outdoor mounted antenna equipped with a preamplifier in order to reliably receive signals from Philadelphia. In this case, my preference would be to 'go large'. But your preference is what counts here.
Do you have a firm budget?
Are you planning to do the installation yourself or will you need to hire help?
If you are on a tight budget or simply don't want to deal with an outdoor installation, the
Antennas Direct SR8 Indoor Antenna may provide one or two more local channels.
