Tv antennas and Tv reception
How many Tv's are/will be connected?? Yes the Cincinnati stations can be received with a with a Channel Master CM95021A rotor. However a rotor is not channel surfing friendly , must wait for the antenna to turn , and not every one will agree where the antenna is pointed if more then one Tv is connected. How many Tv's are/will be connected?? It would be better to have 2 separate antennas / 2 separate antenna systems. The coax of each system will go to the location of the Tv and a Radio Shack #15-1968 remote control antenna switch will select one antenna or the other. How many Tv's are/will be connected??
