Old 28-Jul-2010, 3:04 AM   #17
chumster
Hi,
No I dont have it tilted, but I can with this model. I will try to tilt it tomorrow. When I enter the RF channel it says scanning and then no signal. I am going to try the digital tv first and see what happens. I did point towards WJAC and the converter pauses but thats all.
Originally Posted by No static at all View Post
Do you have the front of the antenna tilted up slightly? I have found this quite helpful in fringe/mountainous areas.
Did you try aiming the antenna towards 287 degrees to see if NBC 6 is available? You can enter channels manually on the Magnavox converter by entering the real RF channel # (34 for NBC 6) & it will find the channel & enter it into the memory if strong enough.
I have tested a few of the Magnavox converters & had excellent results in both deep fringe & metropolitan areas. They have worked just as well as the Zenith, Zinwell & Channel Master models.
chumster is offline   Reply With Quote
