Do you have the front of the antenna tilted up slightly? I have found this quite helpful in fringe/mountainous areas.
Did you try aiming the antenna towards 287 degrees to see if NBC 6 is available? You can enter channels manually on the Magnavox converter by entering the real RF channel # (34 for NBC 6) & it will find the channel & enter it into the memory if strong enough.
I have tested a few of the Magnavox converters & had excellent results in both deep fringe & metropolitan areas. They have worked just as well as the Zenith, Zinwell & Channel Master models.
