Tv antennas and Tv reception
Subject : Antenna cross talk. As you have observed , the UHF antenna aimed to the west receives channels from the north east. And the UHF antenna aimed at the north east receives some channels from the west. The two UHF antennas are out of phase with each other because they are not the same antenna and they are not pointed in the same direction. If the two UHF antennas are connected together on to one coax with a 2 way splitter connected so the two connections go into one , then the two UHF antennas will send , as an example UHF channel 14 down the same coax , the two channel 14's will be out of phase and the Tv tuner will not like it.
