Tv antennas and Tv reception
I recommend that you Do Not combine the 2 DB8's on to one coax , the DB8's are aimed in different directions , the DB8's will cross talk and the result will be bad reception. I recommend that you Do Not connect ALL 3 antennas on to one coax , you will not like the reception results. But then it won't hurt anything so go ahead and try it anyway.
