Tv antennas and Tv reception
The tv Must Scan for the Digital Broadcast Tv Channels sometimes called the 'Air Channels' or 'Antenna Channels' in the tv menu because the transmissions travel through the air from the transmitting antenna to you receiving antenna. Do Not scan for cable Tv channels. If the tv can not scan for the Digital Broadcast Channels then Channel Master has converter boxes , http://www.channelmasterstore.com.
