Thank you Electron. I found the signal strength meter on the Sony. WCYB was very weak, but still held a picture. I went out and tried some adjustments on the antenna and now the picture breaks up and I can't get it to hold and can't get it back like it was. You were right. I had signal loss on every channel with one supply line. The current level dropped and average of 20-30 points on the meter on every channel. Using a single line of the two supply lines, the major channels held a 82-93 signal strength and the weakest other than WCYB was channel 41 and 47. I can't get WCYB to hold now and that is the only NBC station I can get. I'm open for suggestions now.
I think that the SNR reading means signal noise ratio.
What does AGC percentage stand for?
