Tv antennas and Tv reception
I added it all up , the antennas , preamplifiers , coax cables , and etc. , roof top mounting on a two story house with a tripod mount or chimney mount , and more etc. . The cost will be about $700.00 or so. And you do the installation your self. For that you will most likley receive. WTNH-DT 10 ABC and Bounce Tv , WVIT-TV 35 NBC and the New York Non Stop Channel , WCCT-TV 20 The CW and This Tv , WASH-DT 42 Me-Tv and Retro Tv Network. . The Might Be Received stations/channels are , WFSB 33 CBS , WRNN-DT 48 IND. , WTIC-TV 31 Fox and Antenna Tv , WEDH-DT 45 PBS. For all the stations/channels listed here a lot depends on local reception situations such as trees blocking the stations to the east and south east. The antennas will be mounted as far away from trees to east and south east as possible/practical. The antennas will be required mounted Up High on a 2 story house above the roof. Here is the short list of what is required , Winegard HD 7698P antenna with a Antennas Direct CPA-19 preamp , Winegard HD9095P antenna with a CPA-19 preamp. A 10 foot tripod mount on the roof or a Tall chimney with a chimney mount. . ARE You Interested????
