No, but I was told by others that an amp only helps reduce line loss and could introduce noise into the system. I know my setup is not ideal (old directional antenna, old 300 amp flat wire from antenna into the house, then I connect to recently purchased good quality coax to go another 50 ft to the TV location. I can change out the old stuff, but was reluctant to consider that if it still would not make a new set work. Thanks again.
