Old 30-Mar-2012, 11:21 PM   #14
Ken
Combining 2 DB8 antennas
I have one DB8 antenna pointed around 310 degrees using a winegard 8275 preamp and another DB8 pointed around 40 degrees also using another Winegard 8275 preamp. At the present, I am using an A/B switch. Is it possible to take these two leads from their preamps and feed into a combiner and then a single in line to the TV? I was afraid to try this in danger of damaging a preamp if that is possible. Any suggestions appreciated. By the way the DB8 brings in the VHF channel WCYB. These antenn's are supplying signals to 3 TV's. Thanks for your advice.
http://www.tvfool.com/?option=com_wr...0b86f7e1e9da9e
Ken is offline   Reply With Quote
