Old 30-Mar-2012, 6:06 PM   #27
On a tight budget, the ANT-751 makes a lot of sense.
At Amazon,
ANT-751, $48.
2-way splitter, $3.
Factory built RG-6 coax assemblies, $7 to $30 each.
Misc. ground wire & fasteners, $... job dependent.
If you are only going to connect two TVs, keep the cable runs short, and avoid wasting signal in an 8-way splitter... You should be able to avoid the need for an amplifier.
