Old 27-Jul-2010, 10:42 AM   #12
kb2fzq
Originally Posted by olimazi View Post
Thanks man, I am leaning towards the Winegard 7698P VHF-Hi/UHF antenna.
You're right I'm within 40-45 miles from my towers, but I'm a little worried about a big pine tree on my land next to my house in the direction I will be pointing the antenna.
Guess I will have to try and find out - I would hate to mount it and find out that the signal is blocked.
Is there anything I can do to test the signal before I put the antenna up?
Thanks for the help.
Probably only thing you can do that won't break the bank, get an inside style loop antenna at Radio Shack, put it on the roof (on a nice day), maybe 15 bucks for the looper, point loop in the direction you think the towers are, connect a longer cable with a coupler, then connect to a TV and see what you get....it will only be a dipole quality signal, basically one element as opposed to a multi-element of the 7698p, but if you get ANYTHING at all on that insider antenna, you can guess the Winegard will be much better.
That's all I gots...
The pine tree might or might not be an issue, depending on the power at the towers, and how tall and dense the tree is....OTA reception is just a crap shoot anyways, you may get lucky...maybe not....I receive thru a large forest area and I'm good....
EDIT:
You have a few UHF stations running 600+ Kilo Watts of power, one 1000 KW...you may get lucky...
DE K2YI
Hudson Falls, N.Y.
http://www.tvfool.com/?option=com_wr...9fbebf10412194
kb2fzq is offline   Reply With Quote
