					Originally Posted by  GroundUrMast
				The photo of the splitter appears to be a passive 8-way for the cable TV network, true? If so, it should work fine with OTA signals. I see terminators on three ports, so you have five TVs connected? Depending on how many sets are connected and how much cable lies between the antenna and farthest TV, you may need a preamp.
 I think that's correct. I have 5 hookups around the house. I was only using two of them. Will I need terminators on the other three inside the house? It should just be right at the outlet, right? Or should I disconnect the coax from the splitters?
Sounds like I do need a pre-amp. I'll try to estimate how much cash this will set me back to consider my options.
Thanks for all the help.
