To keep it simple and affordable, I would start over. Just mount the ANT 751 on the North side of the house. Run new coax into the basement to feed the basement set. use a simple splitter to feed that set and run a seperate coax to the second set, or if it makes more sense split the coax on the side of the house and and feed the coax from there. Aim the antenna 20 degrees magnetic. This will fulfill your basic OTA needs and preserve your internal cabling, should you ever need or want to go back to some satellite or cable service.
