Old 30-Mar-2012, 12:50 AM   #1
qnssekr
Winegard 7694P in Queens, NY
Hi, I recently purchased a Winegard 7694P antenna and installed it on my roof here in Queens, NY. It's about 25' off the ground pointing 300 degrees west-northwest. I get over 50 channels crystal clear including WNJB. The only problem is no WLIW.
According to the intactive map I should be able to pick up WLIW. So my question is should I point the antenna towards WLIW's antenna? I figure most of the major towers are under 6 miles away and should not be a problem picking up the back end of my antenna. Dumb idea? If anyone has any suggestions how I can get WLIW I would really appreciate it.
http://www.tvfool.com/?option=com_wr...0b8688307937d0
qnssekr is offline   Reply With Quote
