The splitter must pass 50 to 1000 mhz. if it does it will be fine. However If you use the rotor that I recomended, you will need to use a two way splitter with a DC pass to one port ahead of the house splitter. Connect the line that feeds the set located near the rotor control box to the DC pass port of the two way splitter and the other (isolated) port of the two way splitter to the input of the house splitter. This will work fine but you need to use 75 ohm terminators at the end of all unused outlets.
