You may be able to get by with that location due to the signal strength of these near by channels. However I would move it up on that side untill it just clears the top, exposing it to the North but not so noticable from the ground on the North side. Be aware that in the attic would even be better than the shadowed location and would play well, but you would probably have problems receiving the stations from the other directions. As to the cable, all you need to do is eliminate any satellite devices between the antenna and the DTV and be sure to use splitters rated 50 to 1000 mhz.
