Matching amplifier?
After some preliminary tests, I ended up getting 4221HD Channel Master.
I get most channels 21, 27, 33 and 45 with a shorter (15 ft) cable. Once I added it to the Living Room run in the house (straight-no splitters 3 straight through connectors connecting shorter cables), the 33 is very weak and 45s channels disappeared. I tinkered with direction without success.
I think I'll need an amp. Would you have any recommendations for this specific antenna? Would I need one at the antenna or the first 'split'?
Thank you.
I'd like to thank all previous posters for replying.
