Old 11-Jan-2010, 10:30 PM   #5
OTAMAN2010
Check connections
Originally Posted by Steveatus View Post
Just self-installed a Channel Master 4228HD in the attic.
Old TV running off of a converter gets Denver station 31.1. My HDTV doesn't receive it.
I put a splitter right at the antenna and ran the cables directly to each TV.
I can't seem to get the HDTV to show be signal strength, but the A to D converter downstairs is showing about 40%.
1-Check all your connections and make sure there on the right spiltter and tv hook up. Some time folk accidental use the wrong connections. 2-Read the digital scan info, and rescan. 3-Make sure you have a good RG-6 cable with good ends.
Hope this help.
OTAMAN2010 is offline   Reply With Quote
